need a little help
  • urquattro-island
    • Mar 2006
    • 1915
    • Home: Norway Current: Iceland
    need a little help
    have read about boost loss and so on, but can not find what i am looking for.
    My old car s4 aan, is loosing pressure when shifting from 1st to 2nd gear, full throttle on first and it goes like a rocket, then shift to 2nd and it falls down 1,4on the nr in the dashpanel insert, and takes looong to come back up?? Any ideas?? its like the turbo is taking a long time to build back pressure.
    1st gear shows 2,4. Then shift 2nd then falls all the way down to 1,4-1,5 and just uses forever to get back up to speed.
    thanks for replies
    john
    japanischer industriabfall nein danke!!
    www.rackeltrim.se Icelandic Division
  • porkkis
    • 1994
    Read the fault codes. Something keeps ECU dropping boost control off.
    Might also be faulty N75.
    Btw you could improve writing subjects.
