Crank pulley 27mm bolt
  • Pisobiker
    • 1175
    Does anyone know if the 2.5 Tdi engine (AEL and AAT) do have "left" or "right" crank pulley ( harmonic balancer) threaded bolt (the "big" 27mm one)? Having some problems to get it loose so I now was just worried I was turning it the wrong way!!
    Thanks
    Marco
  • Stick Insect
    • Dec 2003
    • 2338
    Marco, would ETKA not say?
    If it is the same part number as another bolt S2 or similar, this may tell you. Other than that I cannot help.
    David.
    • Pisobiker
      • 1175
      OK!
      Got rid of the bolt, finally. It was a std. "right" thread. Problem is Audi applyes loads of Loktite on them so I had to heat bolts head with a welding torch (wet wraps around balancer and over oil pump housing to prevent damage) to burn loktite off.
      Once cooled down it came out quite easy (still needed a 2000 Nm airwrench, though :eek2: )
      Ciao
      Marco
        Now THATs a lot of torque. Awooogah !
        Paul
        • s2driveruk
          • 12696
          Sh*t - i hope mine is a lot less than that when i change my belts!
          David
          1992 3b S2 Coupe
