Originally posted by diesel des
RS2 vs S2 what is different in the engine?
???Originally posted by JamoYes you do oDD, the 7A cam wheel has no trigger for the hall sensor needed on the ABY.
so it MUST be swapped over for the original ABY cam wheel.
If he has an ABY engine, and uses 7A cams. He can uses the ABY camwheel that he has.
YES. Thats what I ment.
But maybe I did'nt understand the question right.:suspect: Yepp! I'm Odd :na:
Audi RS2MTM 500hp/600nm :rock:Comment
Ah o.k, he meant by his question, he's changing to 7A cams, can he run without having to change the cam wheels of the 7A ex cam.Originally posted by oDD???
But maybe I did'nt understand the question right.Comment
Ok, i think i got it right. Just use the Cam pully from the aby to give the pickup. Thats what i have done. BUT i kept the 7A chain sprockets on the exhaust cam and am useing the ABY inlet cam and wheel. OK?Comment
PerfectOriginally posted by diesel desOk, i think i got it right. Just use the Cam pully from the aby to give the pickup. Thats what i have done. BUT i kept the 7A chain sprockets on the exhaust cam and am useing the ABY inlet cam and wheel. OK?
