Just been replacing the vacuum hoses on the car with new hose from VAG parts(3.5mm)
Is this the correct size from the dv to the inlet manifold?Took old one off and seemed slighty larger bore size.
Whats the correct size if this is not right,and what will happen if I use the new tubing I have got.
Is the VAG tubing the correct one generally to use to replace old vacuum hoses
