Anyone know if the 7A 20 Valve Cylinder Head will fit a S2 with the 3B Engine????
I know the Camshafts will fit, so will the head????
The head itself will fit. However you need to machine holes for water manifold. Also, depending on your 7A head, additional machining for the exaust manifold studs may be needed. Search forum for this, there's plenty of info on this.
Sau
