Holding back/Misfire?
  • moony
    • 11
    I have had exactly this problem with two cars a skyline gts and an S2 both times it was the spark being blown out under boost, thats why its better under small throttle inputs, it could of course be a million other things but i would suggest new plugs, it is a very common thing on skylines and cossies I believe the solution is normally to gap the plugs right down or fit stronger coil packs either way spark plugs should be your first port of call as they are the cheapest.
    • YELL MAN
      • Dec 2005
      • 535
      • Country: Shetland Islands
      Mine has boost protection cutting in at the moment but i think this more than likely is the cause.
      1994 Indigo Blue S2 coupe
      1994 80 Avant 1.9 TDI
      2005 Yamaha Fazer 1000
      1953 AJS Model 18S
      • dest
        • 4287
        Well we put new plugs in today (The Bosch ones as recommended on here) and its still exactly the same
        I ordered a 70-60mm reducer to do the MarkH mod, so Im now hoping that might solve it. (Whats the chances of that?)
        • T2Andy
          • 1903
          My hesitation was the Diverter valve not sealing properly ,it is a miltek one in alloy
          and the piston was gummed up where it should seal thus boost pressure would not
          build properly ,hence hesitation .
