MFTS torque?
  • YELL MAN
    • Dec 2005
    • 535
    • Country: Shetland Islands
    MFTS torque?
    Hi could anyone tell me what to torque the mfts to? I have tried searching but so far have come up with nothing.
    Cheers,
    Brian
    1994 Indigo Blue S2 coupe
    1994 80 Avant 1.9 TDI
    2005 Yamaha Fazer 1000
    1953 AJS Model 18S
  • tgriff
    • May 2007
    • 41
    i believe it is 25 Nm on the 3b.
    probably best wait for one of the experts to confirm if its the same for the aby before fitting .
    • YELL MAN
      • Dec 2005
      • 535
      Cheers for that. It will probably take a moment to get it fitted as i have just looked at the size of the socket that will be needed and it seems to be the only one that i don't have
      1953 AJS Model 18S
      • s2driveruk
        • 12696
        have fun trying to get a socket close if the engine is in situ......as for torque not sure but i seem to remember it being quite tight to undo...
        1992 3b S2 Coupe
        • YELL MAN
          • Dec 2005
          • 535
          Yea unfortunatly the engine is still in there. By the look's of it this will be the easer job as i am going to replace the knock sensor's as well.
          1953 AJS Model 18S
          • PeteRR
            • 1326
            It shouldn't be done up too tight, just remember that the threads are Brass when fitting it. I fitted mine by screwing it in by hand until the little washer contacted the water rail/manifold, and then just nipped it up a little further with an adjustable spanner.
            There was also a mention on the SJMautotechnik site about them failing due to possible overtightening. It was seen in some examples that the housing had cracked, or was porous, and the coolant had got into the electronics.
