Radiators
  • john881000
    • May 2004
    • 598
    Radiators
    HI all
    looking for some advice
    does anyone here ....know makers of car radiators,that they can recommend
    need to get a custom set up made
    really looking for west/north yorkshire areas
    doe to fact they might need to see car
    the one i was using(unknown make...non standard) burst on some heavy driving
    thanxs again
    cheers
    john
  • Cullam3n
    • Aug 2007
    • 993
    Probably not going to help you much but when I bought my new radiator from United Auto Distributors, cost me about £140 for mine made by a company called AKG. Having visiting their site, might be what you are looking for. Radiator I received was recent too, built in 12/08. The only other place I know is Aaron's Radiators which doesn't help you, as they are based in London.
    Probably didn't help too much but hopefully got you started
    • john881000
      • May 2004
      • 598
      hi Cullam3n
      cheers for imput
      will get to run through their pages to see what they got and what i might be able to use
      i running a 1.9 tdi with a warmed over engine ecu....and an ABY intercooler
      my avants got the aby IC subframe.....and ..audi 90 front end
      the radiator has to fit in behind the IC subframe,thats why i cant just go out and get off the shelf...
      but if they got specs of rads i can look for a possible match
      and if need be make a brackets foor it
      cheers
      john
      • Cullam3n
        • Aug 2007
        • 993
        Ran across this, this morning
        • john881000
          • May 2004
          • 598
          big thank you
          Afternoon Cullam3n
          you are a star
          went through the first referance and mannaged to pick radiator closer to my needs...........just fitted/bled nd tested rad.......all ok so far ........till i can asfford to get one made to suit.
          2nd referance you supplied was sort of info i was after
          will be saving pennies for proper job.............
          thankyou again(keeping both addresses for future details)
          cheers
          john
          • Cullam3n
            • Aug 2007
            • 993
            cheers mate, hope it works out alright!
            ill pm you my addy so you can post me a pint!
            • john881000
              • May 2004
              • 598
              your welcome
