Parts to use on AAN 400+
  • K7ERG
    • 1711
    Looking around for a head gasket for my AAN.
    It will ne running GT3071R
    I am looking for pointers in what gasket to go for.
    RS2 head gasket
    034 Multi layer gasket
    034 Copper gasket
    034 lower Compression gasket
    Genuine rod bearings
    034 rod bearings
    034 RS2 rod bearings
    Also will it be a benefit to have the 034 adjustable fuel regulator.
    Thanks in advance
    Craig
    Audi A6 AEL 5cyl Quattro breaking.
    Audi A5 3.0tdi Quattro Stage 2
    07947385043
  • K7ERG
    • 1711
    Anyone point me in the right direction of what parts to get.
    Craig
    07947385043
    • mcandmar
      • Apr 2004
      • 5118
      Standard answer is stock RS2 head gasket and ABY/ADU big end bearings. With that turbo you might want to lower the CR? Your going to need thicker head gasket or different pistons in that case.
      Mark.
      P.S. i hope rods are on your list?
      91CQ20v - Gone to a new home
      93UR-S4 - The Magic Carpet
      94S2Bus - The Emerald Express
      • K7ERG
        • 1711
        I have the Scat rods.
        So yours saying the 034 lower compression head gasket
        With the RS2 bearings
        cheers for the reply
        Craig
        07947385043
        • mcandmar
          • Apr 2004
          • 5118
          Not exactly, decide first what CR you want to run, then how best to achieve that. Ideal solution is to buy new pistons, or have the stock ones machined to lower the CR.
          I'd wait to get some first hand opinions for the high HP guys on here before making your mind up.
          • K7ERG
            • 1711
            07947385043
            • mastermind
              • Jan 2005
              • 244
              • Country: South Africa
              I hav used the std RS2 Head Gasket with te GT3071.
              I also bought the 034 RS2 bearings and uprated Rods from 034.
              The Red Baron
              (R)S2 spec, 034 GT3071
              Wagner Short Intake and Intercooler
              Whiteline, Custom Shocks with external reservoirs
              8pot calipers with A8 discs
              Vems
              • K7ERG
                • 1711
                Anyone else what to comment?
                07947385043
                • caterpillar
                  • 2480
                  bigger cams, and bigger fuelpump, bigger injektors, and tubular EM .... and at least garret gt 30-35 turbo, and some custom IC....
                  • K7ERG
                    • 1711
                    Got the GT3071R
                    7a exhaust cam
                    big front mount intercooler 2.5" pipe work
                    tubular manifold
                    3" downpipe and exhaust
                    55lb injectors
                    07947385043
                    • caterpillar
                      • 2480
                      you forgot the fuelpump: borch 044 ( in line) or 040 ( in tank) or similar if you have the thin pierburg item in tank.... the first place it will go bad... no fuel= no power or wrecked engine.
                      • K7ERG
                        • 1711
                        Not sure if it will fit but i usually us a Evo6 uprated pump rated to 600bhp
                        07947385043
                          Mark.
                          Witht the right mapping shouldn't need to lower the CR with a 3071. Standard RS2 metal gasket will do the job.
                          You couldn't use a copper gasket anyway without o-ringing the block!
                          • terrybullwon
                            • Mar 2006
                            • 8782
                            Totally a miss but nice ava Mr Jamo
                            Chef
