Just got in from the garage and have a major problem. The car will not start. It turns over but will not fire.
I got in this evening and decided to swap the knock sensors back to the original ones as I've been havig a few problems with full boost running lately. Swapped one knock sensor over, went for a drive, came back as the same problem was still there. Swapped t'other knock sensor over and then disconnected the ECU from the plug to reset it in case it had stored any faults. Re-connected it and then went to start the engine, turns over but doesn't fire. ******...
I've tried a different ECU with no joy, different MAF, I've checked the fuses in the fuse box, the fuses under the dash and none are blown. I've checked as many plugs as I can see although why they'd go god only knows! The immobiliser is still functioning but I haven't checked hte outputs. I've checked the pins on the ECU wiring loom for power and it seems to be fine.
Basically I'm completely phooked, not thinking straight, tired and trying to figure out how to get to work other than on 2 feet or 2 wheels.
Any sugestions welcome, looking at a day or two off work to try and sort this and yes, I am panicing like a mofo.
