k24-7000 / k24-7001
  • eddiee
    • Sep 2006
    • 17
    • Country: Denmark
    k24-7000 / k24-7001
    can i use k24-7001 (034145703c) insteed of k24-7000 (034145702) turbo on my s2 aby
  • kwlw
    • Sep 2004
    • 1025
    • Country: Lithuania
    Don't know what's the difference in theory, but in practice - there are no known or visible differences between those 7000, 7001, 7002. Maybe housing orientation is different, but it can be easily adjusted. If you want to buy from catalog, check if there is wg nipple on the cold side housing. If not, you will need to drill hole, tap it and use nipple from old turbo,
    Sau
