Aux radiator - bypass/blank off
  • jameswkr
    • 538
    In case you need to do this. My local plumbing agent sells "22mm" joints and blanking plugs in brass with solder rings. These actually measure 24mm o/d and are perfect for the job. I initially bypassed the rad using the joint and last week end cut the hoses back and used the plugs. Access to the front of the engine is much improved and, as previous posts, temp control seems OK and more stable. James.
  • Stick Insect
    • Dec 2003
    • 2338
    Hi James, I have the earlier style grille on my Coupe and was thinking about fitting a pair of long range spotlamps behind/through the grille. I wonder if anyone else had had the same silly idea?
    David
