Boost leaks
  • audiman
    • 4827
    Boost leaks
    The garage weekend provided me with 2 boost leaks. First one was the accordian hose which I cured using a nice peice of SS. Cheers to Bill for that. The second one was the throttle body one. Damn thing.
    The new std one arrived today and after fitment i took it out for a blast. When I used to floor it, it used to make a rushing air type noise behind the dash. This is now gone, making me think that that leak has been there for months. The car now goes like **** off a shovel. Dont think the mapping is quite right tho. When I got home tonight, I lifted the bonnet and the manifold flange - turbo flange was glowing cherry red!!! Me thinks its running a bit too rich(?)
    Mihnea any thoughts?
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
  • Mihnea
    • 1288
    Yup mate, that was to be expected. I was sure I had mapped it on the rollers with a boost leak, but it is not running too rich, but rather a bit (or a lot) too lean. This is why your EM to turbo flange was glowing red. However, how dark was it outside when you did this? If it wasn't dark at all, I'd avoid giving her WOT again until next time I'm in the UK...
    An EGT gauge would have showed you instantly if there was a problem with the mixture or not tho.... now go get one
    Cheers,
    M., still tired as fook from this weekend
    www.MRCTuning.com
    info@MRCTuning.com
    Workshop Directions
    • audiman
      • 4827
      It was pitch black. I dont know what boost its upto now either tho. And yes, soon has i have more money and EGT and boost setup are gonna be installed!
      Its ok. Goes like hell now!! I reckon thats so much quicker than it has ever been!!! Cant wait to see what is going on with the mixture.
      Audi UR Quattro
      • Mihnea
        • 1288
        Hmmm, given peak EGT while mapping it on the M1 was 840°C, I'd be very cautious, it will surely be ok for short bursts of power, but not any more than that...
        If you're looking for an EGT, gimme a shout
        www.MRCTuning.com
        info@MRCTuning.com
        Workshop Directions
        • Dr H
          • 1175
          Tom
          That sounds exactly like my leak. When you floor it under load you get a rushing/escaping air type noise from under the bonnet.
          Roll on the Samcos when I plan to pull the whole thing to peices and find that damn leak
          • Sweeper
            • 1317
            • Country: Latvia
            Oh about Samcos , Paul any news on these ?
            Vadim.
            • APNess
              • 479
              I thought you'd blown your car up again Tom? Or am I mistaken and you *plan* to blow your car up again
              Nice to hear your car is behaving more as it should, though your underbonnet does kind of look like a lashed up nightmare of bits of hoses, steel pipes, and clips all over the place! Team Bodge indeed!
              I had a leak on the throttle body pipe (cured by nipping up the clip) but it felt more like cutting out than losing boost. Looks like I'll have to watch out for a whole new round of leaks when boost gets turned up on mine.
              Roll on the samcos! (Though I gather some of em won't fit on mine now! )
              PJ
              'The Bacofoil Express'...
              No more.
              Leon TDI 150 run in now.
              Very slow.
              Needs a chip.
              • audiman
                • 4827
                Mine would cut out if it was std, but due to the mapping it wont! Always blame the tuner. LOL
                New hose from Audi £14!! It doesnt matter how long it lasts, its dirt cheap, and my stainless mod is stronger than any rubber hose.
                @Mihnea, give me a PM about that EGT. I must get one.
                Audi UR Quattro
                • Doug_RS2
                  • 3847
                  I had that hose to the throttle body break - very similar to Toms. I heard a hissing for a long time before - I think it was a small hole and only opened under lots of boost - eventually I was getting the turbo spinning and a very small amount of boost but no movement.
                  I have mine sitting here if Leigh wants it - I hope I get the samcos before mine goes back together.
                  Can you get that EGT with a smaller display? (or at least a smaller box)
                  • Dr H
                    • 1175
                    Cheers for the offer Doug but I'd hate to take it and then the Samcos arrive late and you have a missing hose when you're trying to put the car together!
                    If it's only £14 I think I might buy a new one :eek2:
