ECU and VAGCOM
  • Azman
    • 3205
    ECU and VAGCOM
    Hi guys.
    Right can anyone on here point me in the right direction to get the ECU plugged in properly to read Vagcom from it. It has been attempted before an we got no connection to the ECU at all.
    Due to the boosting problem I am having at the moment It would be really handy to get a reading of VAGCOM or the blink codes if they are done via a different route.....
    Any help here would be appreciated. I believe it is just one wire that is amis from talking to corey about it but he currently has got the drawing to hand of which one and where it should go.
    The boost problem is driving me nuts so I really need to get this sorted and have a few days off next week to perhaps sort this wire, get it com'd and sort the problem once and for all.!!!
    TGRIFF I may be poping up to borrow your MAF by the end of this week if that is okay.
    Az
    Dark Grey Avant
    RS2 FARB
    Alloy Subframe Bushes
  • GT500
    • Jun 2006
    • 2181
    My connectors only work in the reversed position, ie, try the two connectors opposite way around to the little grooves. Not white on black, black on white! Just turn the ******s 180 degrees.
    Rob..
    87 UR 20v ABY
    97 S6 Avant
    • tgriff
      • May 2007
      • 41
      ok az ,not using the car this week so whenever suits.
      • Azman
        • 3205
        Thats a thought GT500. Cheers will have a look
        Az
        Dark Grey Avant
        RS2 FARB
        • shark_90
          • 1475
          If you're still stuck I have VAG-COM and a proper cable (that works) so I could meet up with you somewhere. My better half lives in Coalville so I'm often down your way.
          1994 Audi S2 Avant - in pieces
          2006 Skoda Octavia vRS 2.0TFSi - goes fast
          1985 Audi 90 quattro - is wet
          Don't forget the East Midlands Meet -Last Tuesday of every month at 7:30pm just off M1 J28!![/COLOR]
          • Azman
            • 3205
            cheers matey. I believe that it is the vagcom part of the ECU that isn't earthed or something along those lines.
            It has been tried with a few cables now all to the same effect. No connection????
            Cheers though.
            Need to figure this one out....
            Dark Grey Avant
            RS2 FARB
              1st off - are you seeing +12V at the black OBD plug ?
              Paul
              • Azman
                • 3205
                Will check. Is that earted to the car then or another pin?
                Az
                Dark Grey Avant
                RS2 FARB
                • Welleh
                  • Aug 2005
                  • 106
                  sorry to bring this thread back up, about a year ago i bought a vag-com cable off ebay, due to having a boost problem too! and it wouldnt work either, i had 12v at the black plug and even went as far as cutting a obd2 plug off a corrado at the scrappy, ringing the vag-com cable thru and chucking it in paralleled off the std obd plugs, but still no cigar! anyone shed any light on this?
