New S2 owner needs a bit of help
  • RoadKill
    • Dec 2004
    • 567
    i now own this car http://www.pistonheads.com/sales/180646.htm
    some of you know its not bosting right so i pull the codes today
    00518 throttle position sensor ( new one fitted)
    Open or short to B+
    00533 Idle Air Control Regulation
    - Maximum adaptation exceeded
    - Mimimum adaptation not reached
    00519 Manifold Absolute Pressure Sensor
    - Signal too low
    - Signal too high
    - Control difference
    00513 Engine Speed Sensor < i now this one gos when car is runing
    how would i check the sensors?
    i all so have a water leck coming from the frunt of the car not had time to look but i think its the water pump , frunt end of to check that out weekend job, also have a larg list of things to do
    replace gear box (think i got one need to check part number so its not a 10v one)
    new bumper (got one coming )
    replace dash lights
    get side mirros working
    get frunt light washers working
    cv joint NS
    roof needs a spray and frunt wing and mirros ( can get this done at work on the cheap)
    back tyre and 4 wheel track
    im shore theres more lol , will get it up in the air at the weekend see what wee can see
    service tec @ East Kent Audi
    S2 ABY
    B8.5 A4
    00533 sounds like a Lamda probe issue.
    MAP sensor might be the pipe to the ecu isnt connected properly or has a boost leak
    • RoadKill
      • Dec 2004
      • 567
      good news , turn out to be a brockon wire on the back of the blug on the throttle position sensor , so its nock out the code 00518 and 00519 and sort the boost as well , all i need to do now is the water pump as its piss water out , getting there
      just need to sort out 00533 , thanks greg s i will pop the lamda out and try it in my mates aby
      S2 ABY
      B8.5 A4
      • kriswithak
        • May 2005
        • 196
        • Home: England
        Ben. You are a git.
        http://forum.funk-hq.com | http://www.no-rice.com
        twolitreturbooctaviavrs - '07 Skoda Octavia vRS - E.R.V.
        It might not be a 5 pot or an S2... but at least I have a 20v Turbo in my life again.
        • RoadKill
          • Dec 2004
          • 567
          see and you sold your S2 you silly boy sir
          would also like to conferm that it is the water pump lecking
          S2 ABY
          B8.5 A4
          • kriswithak
            • May 2005
            • 196
            • Home: England
            Give me 9 months and I might get another one.
            Still a git. Did the third proclaimer get that avant?
            • RoadKill
              • Dec 2004
              • 567
              my cus got it for £1500 got him self a right bargon there that cars runs sweet + i still get to see it and with a bit of luck drive it
              S2 ABY
              B8.5 A4
              • RoadKill
                • Dec 2004
                • 567
                right water pump done all seems good with the boost , but still geting 00533 which gives me a dead spot at 1500rpm , new ISV?
                S2 ABY
                B8.5 A4
