damn
  • urquattro-island
    • Mar 2006
    • 1915
    • Home: Norway Current: Iceland
    damn
    driving to work today my car startet jurking, when hitting 0,5boost. fast on and off like. can anyone relate to this?? Its like fuel no fuel, fuel no fuel, fuel no fuel....
    japanischer industriabfall nein danke!!
    www.rackeltrim.se Icelandic Division
    FP relay ?
    Check connections to FP if you can.
    Any fault codes showing ?
    • s2driveruk
      • 12696
      that sir is a boost leak, is it quite violent with it?
      1992 3b S2 Coupe
      • urquattro-island
        • Mar 2006
        • 1915
        it is
        °very violent, like swithcing ignit. on and off with 1sec in between
        paul, Where is the Fuel pressure relee??
        • s2driveruk
          • 12696
          yep, i reckon you need to check all your intake plumbing, starting at the turbo and following it round to the IM. Top candidates for split hoses are the two leadind up to the pipe running over the rocker cover in my experience.
          Good luck locating it.
          David
          1992 3b S2 Coupe
          • Ski
            • 2591
            lots of things can cause this issue (overboost protection), like a leaking boost pipe, wastegate spring too hard etc..
            PITA to diagnose. I would first inspect the boost pipes to see if youc an spot something obvious (like a big crack).
            ABY Coupe
            • urquattro-island
              • Mar 2006
              • 1915
              ok
              will have a go at it, thought it could be the old hoses. they blew on my urs4 also, stragiht after i chipped it...
              • urquattro-island
                • Mar 2006
                • 1915
                yes
                i recon it will be some searching, i have a 2,5bar map and original wastegate spring.
                  haha - recently chipped 3B on ancient hoses - yes I'm with Dave on this for an air leak and quite a big one by sounds of it.
                  • urquattro-island
                    • Mar 2006
                    • 1915
                    eeehh
                    yes think my hoses are old, (read original 250 000km old)
                    • urquattro-island
                      • Mar 2006
                      • 1915
                      well
                      thanks guys found the leak, and ordered new samcos. (thanks paul) it was the short hose between the pipe from intercooler onto pipe leading to trhottle body...
                      • s2driveruk
                        • 12696
                        glad you found it
                        1992 3b S2 Coupe
                        • urquattro-island
                          • Mar 2006
                          • 1915
                          thanks
                          will be great to get the samcos...
                          • dest
                            • 4287
                            How did you get access to the hose that had the problem?
                            I have the same symptoms as you, but havent checked that hose yet as I didnt know what the best way was to remove it
                              Those two short sections at the lower pressure pipe on the 3B get a lot of engine movement - I've seen those split on a few 3B engines. Those are reasonably simple to bodge a temporary fix.
                              Sometimes the throttle body hose is first to go.
