Cold Starting Firing Issue!
    Ohhhhhh nice sillyscope there Carlos - niftier than mine for sure
    Paul
      Just amazed at the spec on that handheld scopemeter - two channels as well - I want one - its even got video capability for cryin out loud -
      Aim-TTi designs and manufactures advanced electronic test and measurement equipment and laboratory power supplies
      Looks like upwards of US$1000 for a brand new one mind. Too rich for me...
      Paul
      • Flat on my back
        • Jan 2007
        • 2449
        Schhhhh....
        Works scope on permanent loan since no one else knows how to use it, just need high voltage probes so i can check me sparks.
        Means i can sort most me own probs!
        Carlos.
        • Fat Audi 80
          • 10547
          Originally posted by Flat on my back
          Same sensors, different position for the hall sender, off cam instead of dizzy.
          Jpeg at end gives idea of shapes when working.
          Good luck.
          Sorry! Didn't read it all, thought you were on about a dizzy fault re: the non starting....
          Cheers,
          steve.
          The Perfectionist
          • Fat Audi 80
            • 10547
            Car has been fine today. I will keep an eye on it. I am not taking it apart unless I have to!
            (Its not a daily driver, so I am not bothered at the mo')
            I will resurrect this thread if needs be.
            Cheers,
            Steve.
            The Perfectionist
            • Flat on my back
              • Jan 2007
              • 2449
              Ah ha...
              Threats of grubby mitts and probing with long screwdrivers made it work again! Also leaving overnight for the magic mechanic faries often works.
              Veeeeeeeery technical this fault finding, leave to the experts!
              Carlos.
              • Fat Audi 80
                • 10547
                Cheers Carlos.
                The Perfectionist
                • 220bhp
                  • 2578
                  • Home: United Kingdom
                  #23
                  I had exactly the same problems on my s6,it would run ok for days then let me down,it would always start in the end some times afew seconds ,sometimes anhour or so.Put up with it for weeks while I checked this and double checked that,in the end dessided to bight the bullet and do the hallsender. This fixed the problem and its been fine ever since.
                  • Fat Audi 80
                    • 10547
                    Cheers.
                    Will probably have to do it eventually...
                    The Perfectionist
                    • Jas11n
                      • 5067
                      Don't forget Steve, the car might start well enough, but if the hall sender signal fails whilst you are driving, the car won't stall but the ECU will disable knock control, limit full boost to 0.4 bar and retard ignition (IIRC 6 degrees ,but don't hold me to that)
                      It can also bring on overboost protection on WOT over "I think" 4500rpm.
                      Bro has been there and had us stumped for a while chasing other potential sources of these above.
                      Jas..
                      2001 Avus Silver B5 RS4.
                      1995 S2 Coupe - sold (sniff)
                      • Fat Audi 80
                        • 10547
                        Thanks Jas.
                        Just got back from hols and going to try and start the car now.
                        Finger crossed....
                        Cheers.
                        Steve.
                        The Perfectionist
                        • Fat Audi 80
                          • 10547
                          Working perfectly again.
                          Go figure.
                          The Perfectionist
