intake temp sensor on IM
  • s2driveruk
    • 12696
    does the ABY one fit the 3b?
    1992 3b S2 Coupe
  • topsparky
    • Oct 2005
    • 2014
    i think it does mate WAB took mine when i wrote mine off
    and his engine runs ok
    ask azman coz its in his car now
    1. SHORT SHIFT KIT
    2. PORSCHE CAYENNE CALIPERS
    3. H & R SPRINGS
    4. BILSTEIN SHOXS
    5. NEW BUSHES AND HP2 STRUTS
    6. UPRATED HIGH OUTPUT COIL PACK
    7. ,3" turbo back s/s/ exhaust
    8. fmic fitted
    • Jas11n
      • 5067
      Both (3B and ABY) pull up the same part number for me, 034 905 379 B.
      Jas..
      2001 Avus Silver B5 RS4.
      1995 S2 Coupe - sold (sniff)
      • Azman
        • Sep 2005
        • 3205
        Sore point at the moment So not a good idea to ask me as I can't figure out the bad running on the engine.....
        But I am sure that the part works fine....
        Az
        Dark Grey Avant
        RS2 FARB
        Alloy Subframe Bushes
        • s2driveruk
          • 12696
          reason i ask is that the temp sensor on the 3b is hardwired but the ABY one unclips and as i ripped mine off when i removed the engine, duh! forgot to disconnect it, had undone the screws but not gone back to it, the clip version seems a more elegant solution
          1992 3b S2 Coupe
          • Acidburn
            • 13459
            and easier for future removal of engine etc.
            • s2driveruk
              • 12696
              indeed that was my thinking...
              1992 3b S2 Coupe
              • Jas11n
                • 5067
                The FA says if you replace the one on the 3B you also need 443 906 232 which is a 2 pin flat contact housing.
                Hardwiring solution sorted
                • s2driveruk
                  • 12696
                  I shall order it now cheers Jas
                  1992 3b S2 Coupe
