Uprated fuel pump on URS4
  • K7ERG
    • 1711
    What is the best uprated fuel pump to use on the URS4?
    Audi A6 AEL 5cyl Quattro breaking.
    Audi A5 3.0tdi Quattro Stage 2
    07947385043
  • topsparky
    • Oct 2005
    • 2014
    tried and tested route is the bosch motorsport 044 fuel pump
    check ebay or give corey a ring
    1. SHORT SHIFT KIT
    2. PORSCHE CAYENNE CALIPERS
    3. H & R SPRINGS
    4. BILSTEIN SHOXS
    5. NEW BUSHES AND HP2 STRUTS
    6. UPRATED HIGH OUTPUT COIL PACK
    7. ,3" turbo back s/s/ exhaust
    8. fmic fitted
      Well besides the Bosch 044, the Bosch 005 (also a 60 mm dia pump) works. 034 has both as "drop in kits" (needs some fitting, so I am told).
      In the short run, you can also relay the stock 091G fuel pump directly to battery as per my instructions in the AudiWorld UrS car FAQ:
      http://forums.audiworld.com/s4s6/msgs/149790.phtml
      HTH
      • urquattro-island
        • Mar 2006
        • 1915
        • Home: Norway Current: Iceland
        hei
        i used a 040 bosch pump, works sweet. almost same parts needed as 044
        japanischer industriabfall nein danke!!
        www.rackeltrim.se Icelandic Division
        • merlin's S4
          • Jan 2005
          • 1539
          Out of interest, what's the BHP limit of the stock pump? Will it cope with high power with the direct wiring mod?
