3B Distributor - Available?
  • faaaaast
    • 124
    Getting mixed reports about these going unavailable. Apparently it depends on chassis code, year, and make of disti fitted.
    Can anyone clarify definitively, please?
    Cheers,
    James
    '91 S2 Coupe
    '92 A80Q 2.8 V6
    '92 A80 2.8 V6
  • terrybullwon
    • Mar 2006
    • 8782
    Cheers,
    James
    Did you not see my brand new spanker? (*Sold*)
    There are two used iirc, a later and a early model. I think the early flavour maybe NA
    Hope this helps
    Chef
    • s2avant
      • 2426
      There are two versions as mentioned above.
      034 905 237 BX which fits cars up to chassis number 8B-N-005500
      034 905 205 AA which fits cars after 8B-N-005501.
      It is the later one which has been obsolete since 18/07 this year. This is probably down to the fact that there will be very few 3B engined coupes made this late (December 1991)
      Ben
      • faaaaast
        • 124
        Ah, this may well explain it!
        So, if you were to have a car with the later part no. what is the workaround??
        Cheers,
        James
        '91 S2 Coupe
        '92 A80Q 2.8 V6
        '92 A80 2.8 V6
        • faaaaast
          • 124
          This might explain the mixed reports I've been getting!
          What's the workaround/part if you did have a later 3B? Or are the two interchangeable?
          Cheers,
          James
          '91 S2 Coupe
          '92 A80Q 2.8 V6
          '92 A80 2.8 V6
          • faaaaast
            • 124
            Apologies, thought the first of my previous replies had been lost due to computer crash!
            James
            '91 S2 Coupe
            '92 A80Q 2.8 V6
            '92 A80 2.8 V6
