Ok the copy rs2 injectors from 034 seem to not work with the stock clip that holds the injector to the fuel rail. On My AAN the stock injectors had 2 groves and the "clip" goes into the top grove and holds the injector on the rail. The bottom grove does nothing.
On the 034 there is only 1 grove and its at the lower level so the clip wont grip it. Is their a different clip to use? I have it built up and on the car and it runs ok but just scared of it coming loose and pumping fuel round the plant room.....
