VAG-COM Virgin. Error help req'd
  • Bram
    • Aug 2006
    • 2582
    Originally posted by S-Express
    Hi Bram, I got the test OK message but couldn't get any info from the ecu re engine (or any other system for that matter). I also tried lowering the baud rate right down to slowest.
    I have exactly the same behaviour on mine. Let's try to find out if the additional OBD cable is faulty then....
    Does someone know the electrical diagram for this cable?
    • S-Express
      • Nov 2006
      • 1133
      I did put a meter on the connections and got a link from each contact on the black+white plugs. I actually got 2 links from one of the black contacts.
      A schematic would help .......
      • Bram
        • Aug 2006
        • 2582
        Remember that the problem still can lay in the Vag-com unit instead of the 2x2 cable. I read somewhere that a more expensive HEX vag-com cable is more reliable when using the 2x2 cable instead of our cheap vag-com unit.
        • spink
          • 4382
          Originally posted by shark_90
          All I can say is buy a proper cable...
          nothing wrong with the alphabid cables,i actually used to have a genuine vagcom setup which was about 200 quid.I sold it when i found that the alphabid ones work fine.Some cars just do not want to work with it(genuine or not),had it on one of mine.Works 100% on any others ive tryed.
          • S-Express
            • Nov 2006
            • 1133
            #20
            Cheers Spink - will keep trying until it gives up the fight and lets me in!!!
            • S-Express
              • Nov 2006
              • 1133
              #21
              Tested the cable on a mates A4 worked fine, also works on my passat, I therefore conclude that its the 2+2 cable that fails.
              (as the other 2 car use the bigger plug)
              Can anyone bleep out the connections on a working 2+2 cable and us fellas that can't talk to our cars can compare ours.
              cheers
              • a25c
                • 259
                I have the alphabid cable aswell.I had the exact same results as you had and spent the whole weekend trying to get it working on the car to no avail,gave up trying.It's gathering dust somewhere now!
                96 UrS6
                96 UrS6 Avant
                Previous:
                '87 coupe quattro, '85 90 quattro
                '95 S2 Avant '89, 200 quattro 1b
                '00 Allroad 2.7T, '02 S6 V8 Avant
                '96 A6 2.5 TDI quattro Avant.
