An Inconvenient Problem
  • Mark Halligan
    • 2001
    Originally posted by spink
    Were you planning on taking it to ADi this weekend?
    James
    No mate wont be able to get there with or without the motor.
    Mark - Modded
    • spink
      • 4382
      bummer,been wanting to see your car on the track for ages now.
      • sal_s2
        • 1287
        Maybe it was the supersionic breather system
        Probably just a bad batch of valve seals
        • Mark Halligan
          • 2001
          LOL, Nah can't be that was super high tec don't you know
          Mark - Modded
          • volcano rs
            • Jun 2005
            • 2265
            if you stand too close to that it would probably suck you into the engine
              #21
              Smells to me like a bad batch of VSOS - only way to explain some being much worse than others. That must be a real PITA with all the build/rebuild that you are doing Mark.
              As a related question - Is there any real benefit from these exotic multi-angle valve seats ? I have always thought they were an expensive 'necessity' designed by engine builders with the machinery to do the job and charge accordingly... Being a bit sceptical there for contraversy but I've honestly never seen any quantified benefits from them versus a traditional single angle cut that is well done and ground in.
              Paul
