Turbo pipe sizes
  • Azman
    • 3205
    Turbo pipe sizes
    Hi guys,,
    Can anyone tell me the ID needed for a 90deg pipe from the stock turbo...
    Az
    Need the figures really quick so I can get the pipes made for me and get them on the car tommorow afternoon.
    Dark Grey Avant
    RS2 FARB
    Alloy Subframe Bushes
  • Azman
    • 3205
    Anyone??? Just after the external diameter of the stock K24 outlet????
    PLEASE!!!
    Dark Grey Avant
    RS2 FARB
    • Azman
      • 3205
      Anyone.... Mr Parts Guru are you about????
      Dark Grey Avant
      RS2 FARB
      • jameswkr
        • 538
        Oh, so it was the hose then....
        Turbo outlet hose measures 50mm ID. BUT (see my previous post under your "it never rains" thread) this hose is not a simple 90 degree. It also has the feed to the DV on it. This is moulded in one piece on the original but the Samco kit comes in two pieces. You wont get that made quickly im afraid ( unless you have taken the DV out of the plumbing altogether).
        • Azman
          • 3205
          No the DV is still there. Am planning a complete stainless piece to cover the section with only a joiner at the ends and one for the DV. I have a metal piece there at the moment with just the two 90 deg bits on the end and the DV.
          Just thinking of making things a bit more robust under pressure..
          Cheers matey.
          Az
          Dark Grey Avant
          RS2 FARB
