HT Leads
  • Sammo
    • Sep 2007
    • 60
    HT Leads
    My 1992 S2 has a missfire under boost. I have changed the plugs and now want to change the leads aswell. However no motor factors sell them and they are stupidly expensive from Audi! Nearly £30 per lead!!!
    It is the 3B engine!
    Anyone know where I can pick up some leads for a little less than that as my wallet is not quite that deep!
    Sammo
  • bazookachicken
    • Jul 2006
    • 157
    Hi there,
    Have you tried vagparts? They stock a lot more than they list on the website and I'm sure they'll be cheaper than Audi great guys to deal with.
    Also possibly Pete @ quattro corner or Corey at quattronics although I don't really know if they will have them I'm sure they could tell you where to go if they can't get them
    Alternativly try MSW on the net they have Magnecor ht leads listed for the 3b at £110.88 a set so roughly £22 a lead check out www.motorsportworld.co.uk
    I've used them before for parts and they are always a pleasure to deal with.
    Rich
    1995 S2 Avant
    Homefries,
    RS2 intercooler,
    996 monoblocks,
    Koni adjustable shocks,
    H&R springs,
    18" RS6 reps in anthracite.
    150K and running great
    • Azman
      • Sep 2005
      • 3205
      If you are replacing them all I would go for the magnecor set and even possibly their upgraded 8mm ones..
      Hve you checked the dizzycap and rotor arm?
      Dark Grey Avant
      RS2 FARB
      Alloy Subframe Bushes
      • S2_Dave
        • Aug 2005
        • 456
        You can use 7A leads in the 3B. I'm using 7A leads and still have the cover on. GSF sell a 7A lead set for about 60 quid.
        David
        '91 3B S2 Coupe
        • Sammo
          • Sep 2007
          • 60
          cheers for the help guys. I think I might save for a couple of weeks and get the Magnecor ones!
