I did my crank seal and changed the crank sprocket on my 20v today, refitted everything.. seems to be running fine, smoother than before and idling very solidly - also replaced the alternator , alternator bracket and snub mount, all of which were cracked and about the fail.
There is more noise coming from the cambelt than before, not a 'scary' noise, but a more pronounced 'whiring' sound - is this normal with a new cambelt, or possible it just needs to bed in a bit?
All belts are tightened correctly, about 10mm of flex in the drive belts, and just able to turn the cambelt 90deg between finger and thumb...
Any thoughts?
Any thoughts?
Put your fingers on a lower torque setting.
