so, good evening folks, i need you help,
rite so the car (aby with 156,000miles with mrc remap) is rather lumpy when you floor it. it like a pulsing sort of sensation, it just doesn't feel smooth, also it hits what i would call fuel cut, (it boosting about 1.3bar when it hits it)
so i pulled the codes and i got 4444 first time (that's injector number 1) know i don't think that thats the problem. so i reset the codes and took it for a drive. got back and pulled the codes again and this time i got 2111.
so 2111 is the engine speed sensor, now bare in mind i had the engine off so i turned it on and still got the code, i didn't reset the ecu,
also the car runs smoothly off boost.
so my bets on the maf, i cleaned it about 2 weeks ago (with wd40) to see if that would fix it, seem to fix it for a week or so.
so has any body got any ideas
