Hey guys,
My head is currently off and i have the oppertunity to do some work on it.
I havent really seen any users, using oversize valves on the forum.
I'm doing a head port and cutting the valve seats, would like to know if its worth using oversize valves on the exhaust. and what size ?
I'm using both 7a cams , GT30 turbo and high rate valve springs.
the bottom end is getting a stroker crank and pistons are 82.5mm.
displacement will be 2.5L. chasing 600hp on this setup.
any info on bigger valves will be helpful.
