Is the 1.8T engine as strong as I5 engine?
  • 1975DCS
    • Sep 2006
    • 258
    I was having a chat with friends about some turbocharged engine and the following came up:
    The 5 cilinder engines have a very good reputation for having a very strong block, especially the block itself (the non rotating parts). We were wondering if the 180-225 bhp 1.8T is a good offspring of that...
    Yes there are some similarities, they all have the same bore etc. And yes there are differences, we know the newer 1.8T engines have improved electronics and smaller but quickers spooling turbo's and are more set up for smooth driving than big bhp.
    Maybe the rods are also stronger on the I5, but if fitted with the same pistons and rods, could a 1.8 still handle the same bhp per litre as the I5 engine? Maybe the walls and bearings are smaller because it is build more compact, making the engine more fragile? Maybe the casting of the block is less good? Maybe you need nikasil liners, like they do with high boosting Cossies and EVO's?
    Is anyone in the know? Anyone seen both engines in detail?
    Ps. in Rallycross there are several VAG engines (even after the Audi S1 and S2 days) running massive boost and get heavily abused. Some of those 4 pots are 20V, some are 16V. Some have dieselblocks, some were 1.8's rebuild to 2.0 (I guess) others are basicly 2.0. For the 2nd time in row Lars Larson with the Skoda Fabia with Trollspeed beat the highly developed Citroëns (Snobeck) and Fords (Trollspeed and Julian Godfrey). I don't know what engines are used in the WRC's (but they are build by Lehmann)...
  • gnutz2
    • Aug 2006
    • 928
    From experience i know the AGU 1.8t (which has the bigger inlet ports) can take around 300 ft/lb an d 350 hp, also this engine has foged mhale pistons as standard and i think this is true with all the forced induction 1.8t engines.
    As for serious grunt there is a certain company using gt35r turbos on the 1.8`s and touching 600hp (in a narrow rpm band), obviosly the internals are upgraded but i dont think the block has any support but im not sure.
    The ONLY S2 Golf!
    10.42@138mph
    • Animal Mother
      • Jul 2007
      • 1135
      I know of a few companies tuning them to 400bhp without changing internals.
      UrS6 - Homefry, Bailey DV, PiperX filter, Samco hoses, H&R springs, 3" D/P back zorst, 270bhp and 260ftlb :rock:
      Triumph Daytona 955i - mmmmmm :fire:
      80 dag dag :driving:
      • shark_90
        • 1475
        I had a 1.8T Golf for a while and according to what I read on ukmkivs.net the AGU 1.8T was the strongest engine if you were going for big power.
        I don't know what they go up to though.
        1994 Audi S2 Avant - in pieces
        2006 Skoda Octavia vRS 2.0TFSi - goes fast
        1985 Audi 90 quattro - is wet
        Don't forget the East Midlands Meet -Last Tuesday of every month at 7:30pm just off M1 J28!![/COLOR]
        • 4WheelDrifter
          • Oct 2004
          • 5773
          • Country: Devon
          I know APY (1.8T 210 PS) cranks don't like >600 Nm (440 lbs/ft). Mihnea has a BTDT.
          SS
