3B distance of the screw in wastegate???
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    hi friends,
    anyone knows wich is the distance of the screw in the wastegate cover in the S2 3B model with the factory stock??
    one day a friend said me 1,4 cm,but i am not sure and here sure there are a lot of mechanical s2 3b masters who can know about that.
    thanks in advance
  • s2_bo
    • Oct 2005
    • 6067
    If you have a screw in your wastegate top compressing the spring then its been tempered with.
    Usually the sign of cheap and cheerful tuning. Is there a bleed valve on the WGFV too?
    From factory / stock there is no screw.
    However the further down its screwed the more pressure on the spring and the longer it will take for your wastegate to open when coming on boost.
    Most people on here will advise against this "mod"
    Good luck.
    Bo
    91 S2 coupé - RIP
    98 S8 - Luxury barge
    • Rocco
      • Aug 2007
      • 6393
      • Country: Spain
      Good luck.
      Bo
      thanks for answer me, mmmm.. you said that,the wastegate dont have screw in the factory stock?? .... i am talking about the HEXAGONAL screw in the up side of the wastegate.i saw that in all S2 wastegates... and ask if someone know which is the distance of the hexagonal screw since the the top up of the wastegate in the stock factory
      thanks again for the help,and i am sorry for my **** english i hope all people can understund me
      • Rocco
        • Aug 2007
        • 6393
        • Country: Spain
        arggggggg
        just after read 2 times you post,i understund it in other way.
        you wanted told me about the factory stock screw is nothing screwed down nothing ok?? i am in true?
        sorry...
        • s2_bo
          • Oct 2005
          • 6067
          Yes thats it
          This is what a stock waste gate should look like:
          If you have a bolt in there then that was done after the car left the factory to increase spring compression.
          So i guess to answer your question regarding screw distance. First of all it depends on the length of the screw. As they are not a standard length.
          Then it depends on whether or not your car is chipped and weather there are any other "modifications" to the boostware.
          91 S2 coupé - RIP
          • mcandmar
            • Apr 2004
            • 5118
            I think he means how far down should the original hex nut be set to. I.e. to return to factory settings.
            Only thing i can think of is to disconnect the WGFV and keep adjusting until you get .4bar or whatever the stock figure is.
            91CQ20v - Gone to a new home
            93UR-S4 - The Magic Carpet
            94S2Bus - The Emerald Express
            • martinjs
              • 3205
              Its documented on here somewhere, i remember reading it a few years ago. There is a certain distance from the step of the perch to the inside of the wastagate cap for stock setting.
              • s2_bo
                • Oct 2005
                • 6067
                Originally posted by Rocco
                arggggggg
                sorry...
                Sorry Rocco,
                I misunderstood your question.
                I think what your referring too, is the nut that is screwed on to the top of the wastegate Valve.
                Sorry about that. Please ignore my other comments.
                Hopefully someone here will know what the correct distance is.
                Bo
                91 S2 coupé - RIP
                • s2driveruk
                  • 12696
                  10mm from memory from the perch?
                  1992 3b S2 Coupe
                  • martinjs
                    • 3205
                    Remember the 'matchstick method' lmao
                    • martinjs
                      • 3205
                      Found it, its all in this thread.
                      • s2driveruk
                        • 12696
                        straight from the bent paper clip technology dept for gearbox/diff fluid micro-measurement
                        1992 3b S2 Coupe
