Head gasket and cam belt replacement
    Looking to replace the head gasket and cam belt on my ABY so looking to get a list of the parts I need to do the job properly and where's best to get them from. I've looked at a few old threads but thiongs change so I want the latest info as many have been building engines recently. Car is to be capable of RS2 spec in the future.
    Current list for use with RS2 water pump:-
    Timing Belt - 054 109 119H (RS2 item for RS2 WP)
    Water Pump - 054 121 004AX (Exchange) - (RS2 WP?)
    Bolts to fit - N 010 247 8 (x2)
    Bolts to fit - N 014 717 2 (x1)
    Seal - 035 121 043
    Cam belt idler 078 109 244 F
    Cam belt tensioner 054 109 242
    Alterator belt - 034 903 137B - 14.24x888mm (Ribbed)
    Crank Pulley - 034 105 263A
    Bolts to fit Pulley - N014 726 3 (x4)
    Crank bolt 034 105 229 A
    Crankshaft Oil Seal - 034 115 147 A
    Turbo to EM bolts
    Turbo to down pipe bolts
    Turbo to EM gasket
    Turbo to downpipe gasket
    2 wastegate bypass pipe gaskets.
    RS2 Head Gasket 034 103 383 AD
    Head Bolts 034 103 38J C
    Coolant - G12+
    Already replaced thermostat
    Optional:
    Hall sensor
    cambelt cover
  • Faheemo
    • Feb 2005
    • 544
    • Country: South Africa
    WARNING - Head gasket prices are big $$. Just bought one, and was shocked at the prices.
    S2 Coupe fully built.
    10.9 1/4mile 0-100 in 3.5secs
    Precision 6262 turbo
    The Green Monster
      @Andy - thats spooky - I've just posted a long list of parts to Martyn & Co for a similar job - major service time on mine with regards timing belt and such. I need to change the upper gaskets in the cam cover - leaving the head there for now.
      Comparing your list with mine...
      That timing belt and water pump are ABY parts from my info - not RS2 items as you state. New water pump comes with seal/gasket - dont need it separately.
      Bolts to fit - N 014 717 2 (x1) - I have x3 listed from my info plus washers
      I'm showing different tensioner/damper than you as well (054 109 479A) - weird
      Here's my list of timing belt related parts for ABY - got me worried now so I'll go double check
      109-70 2 054 109 119 H
      109-70 4a 054 109 479 A
      121-15 1 054 121 004 AX
      121-15 3 N 014 717 2
      121-15 3a N 011 670 16
      121-15 5 N 010 247 8
      121-15 5a N 012 241 10
        On my family album the RS2 timing belt is 034 109 119C (for Charlie)
        RS2 water pump is 034 121 004B (for Bravo)
        Note also the tensioning damper is common to ABY/ADU and that it incorporates the relay roller when ordered as 054 109 479A
        Oh but forget my nonsense about N 014 717 2 - just need one of those OK - not 3 as I said before... Brain fahrt.
        Paul
          Head gasket set from GSF here in the UK is £69+vat and is what many have used.
          Paul, I'll check the items off and going to get them on order. i don't service mine as it's in my garage every weekend (well it seems that way!). Cheers for the part numbers. Mine were taken from a previous post. From what I've read, the RS2 water pump is over-driven so that it pumps more water and thus cools the engine better.
          I'll post the final parts list and where I get things from when I've finished it.
          • DarrenM
            • Aug 2007
            • 1227
            Mines going in a few weeks for Headgasket & Cambelt, was advised on high compression H/gasket if im gonna be uprating Turbo in not to distant future. Is the GSF RS2 gasket quite a capable option then?
              I think you want a low compression HG for a high pressure turbo car, unless you mean a higher strength HG?
              The GSF one is supposed to be just fine, I'm sure that there are quite a few using it without problems. I think that Chen, Bo and 4WheelDrifter are all using them for 400bhp but don't quote me on that just yet.
                GSF one is Victor-Reinz kit, comes with valve stem seals and all other gaskets.
                You can also get them from Pete at Quattro Corner.
                • s2_bo
                  • Oct 2005
                  • 6067
                  Yup
                  the Victor reinz kit should do the trick.
                  If you buy it from GSf make sure you get your 10% discount
                  Good luck.
                  Bo
                  91 S2 coupé - RIP
                  98 S8 - Luxury barge
                  • DarrenM
                    • Aug 2007
                    • 1227
                    Cool, thanks for the info guys!!
                    • Knight Rider S4
                      • 3541
                      I put the GSF one on as well... very good and a good price
                      Would advice buying exhaust manifold studs and replace the lot of them as some will probably snap on you as they did for me and while the head is off replace the pipe that runs from the thermostat to metal pipe under inlet manifold that goes to heater matrix (total PITA to fix when all together)
                      93 S2 Avant Parting
                      91 URQ RR
                      02 A4 tdi Avant
                        Cool, didn't know we had 10% discount! Head gasket from VAG Parts is £45, GSF kit is £41. Not going to replace stem seals as it doesn't really use any oil and I can do this at another time anyway. Cheers for confirming Bo
                        Hose you refer to has been replaced already but top tip, mine was knackered and Jas11N's went bang the other week
                        Going to replace all exhaust studs, nuts gaskets as something is blowing. Also going to inspect the EM and DP whilst doing this work and the clutch to look for serious cracks. Also might replace imtet gasket whilst I'm there.
                        Going to be a long weekend of fun!
                        • 4WheelDrifter
                          • Oct 2004
                          • 5773
                          • Country: Devon
                          Have you included the gasket/seal for the oil return line from the turbo to the sump?
                          I have found it easiest to undo the oil line at the sump end first to get the turbo/head off.
                          SS
                            I'll add that to the list... just starting to think about exhaust options now!
