What else can it be?!
  • dest
    • 4287
    My car has had a misfire/holding back on boost problem for ages now
    It has had:
    New plugs (correct recommended ones torqued correctly)
    New WGFV
    New dump valve
    New intercooler due to hole
    All boost hoses checked for leaks, leak test done and is now ok
    We are going to put some 1.8T coils on on Friday as now the boost leak is sorted, its still doing it and feels/acts like its definitly looking like an ignition problem
    I just hope it fixes it, if not, what else could it be?!
  • shark_90
    • 1475
    Sounds like what I had, and new coils sorted mine out
    1994 Audi S2 Avant - in pieces
    2006 Skoda Octavia vRS 2.0TFSi - goes fast
    1985 Audi 90 quattro - is wet
    Don't forget the East Midlands Meet -Last Tuesday of every month at 7:30pm just off M1 J28!![/COLOR]
    • terrybullwon
      • Mar 2006
      • 8782
      Sounds like it could be coils or maybe knock sensors? Will the engine do it at a stand still whilst been taken through the rev range? I have some coils you can try
      Chef
      • mdm
        • May 2007
        • 65
        same here, 1.8 coils fixed mine
        • Bowlerwell
          • Sep 2005
          • 1052
          Have you pulled fault codes?
          John Bowlerwell
          Electronic Engineer
          Present:
          Nogaro Blue RS2 - TOE
          Previous:
          Kingfisher Blue S2 - UAA
          Volcano Black RS2 LHD - DEX
          • Crawford_S2
            • 1555
            Recently replaced fuel pump/filter/regulator to sort mine out, did a service and some other odds and sords too so not sure it was that but feels good now!
            Ragusa Coupe gone!
            • Rusty
              • 18953
              Have some nock sensors you can try if you want. Sounds like coils to me though, I believe that Jas11n had a wiring issue with one of his coils and this caused either a hiccup or running on 4...
              • Acidburn
                • 13459
                Would be good to try some of the stuff dest before you spend out on something that you don't need (but will save you doing it in the future)
                • CHEN
                  • 329
                  Maf?
                  • 220bhp
                    • 2578
                    • Home: United Kingdom
                    Are these symp'toms you have, like a hiccup,only when driving and only below 3000 revs, or do you get a missfire at stand still.
                    • Briggsy
                      • Jul 2005
                      • 267
                      i had a simillar problem on 2 occasions both different issues, but they were firstly the coils and then a few months later i had to change the MAF and it has been fine ever since!
                      1995 B4 Audi 80 S2 avant 267bhp and 326lbft *sold*
                      2001 P38 Range Rover DHSE 159bhp and 255lbft
                      1985 Type85 Audi 90 quattro 135bhp 140lbft
                      • dest
                        • 4287
                        When it is at idle it runs perfectly, if you rev it in neutral it is perfect too.
                        As soon as you start to give it any more that light throttle above 2k it starts to hold back. Best way to describe it is as if it was about to run out of fuel.
                        Also, when changing gear there is a slight hesitation after putting your foot back on the power, which also suggests ignition.
                        Jamie (my tuner) had when he drove it, he could see the unburnt fuel out the back when on WOT, again, a sign of an ignition problem!
                        So, we will fit some 1.8 coils on Friday, and go from there
                        Thanks for the offers of trying coils to save money, but thankfully I have been given 4 1.8 coils for free, and the 5th is only £15, so not really a big outlay!
                        Hopefully my next question will be who can point me to one of those covers that replace the original coil cover that cant be used
                        EDIT:
                        I forgot to say I had given the MAF a good clean too
                        • dest
                          • 4287
                          I have just realised I havent got any of the connectors needed to create the new loom for the 1.8 coils, so wont be able to fit them tomorrow
                          Terry, Id like to take up your offer of trying your coils if possible, how can we go about that?
                          • Al Wyn
                            • Nov 2006
                            • 3746
                            Dest... re terrybullwon (James) will txt him for you
                            S2 + RS2 yep ive had a few love em... Laser red S2 avant... Brilliant black lhd RS2... Polar silver RS2... RS blau RS2... CheeRS Al
                            • dest
                              • 4287
                              Ive also sent a pm to Corey, hopefully he will have one of those 034 1.8 conversion looms in stock, it will save alot of messing about!
