Does anyone know the crank angles between 1,2,4,5 and 3.
  • gnutz2
    • Aug 2006
    • 928
    As i said in the title does anyone know the crank angles between cylinders 1,2,4,5 and 3.
    I need to put the info into the S100 DTA ecu that im setting up
    The ONLY S2 Golf!
    http://www.s2forum.com/forum/showthread.php?t=19402
    10.42@138mph
    https://m.youtube.com/watch?v=0wnkkOfFpXg
    Already replied in your previous thread - maybe I'm not understanding your Q properly.
    • gnutz2
      • Aug 2006
      • 928
      Sorry Paul i must have missed your reply.
      I see what you are suggesting 72 Deg.
      Maybe some of the Vems boys can confirm their findings?
      The ONLY S2 Golf!
      10.42@138mph
      • Gringo
        • Jan 2005
        • 139
        What`s there to find ? 360 degrees of crank rotation divided by 5 cylinders is 72 degrees. For full sequential fireing you shoud have a spark at every 144 degrees for each cylinder.
        Now you see me, now you don`t
        80quattro.com
          Thats how I see it... 144 degrees is 54 flywheel teeth (if my assumption of 135 teeth is indeed correct).
          • gnutz2
            • Aug 2006
            • 928
            So its not 72 deg between each pot like you seggested Paul.
            It`s 144 deg angles between cylinders.
            The ONLY S2 Golf!
            10.42@138mph
            • Flat on my back
              • Jan 2007
              • 2449
              72 degees is right for the crank, angle at which the rod centre is found.
              144 is the number of degrees for each firing point, remember 4 strokes rotate twice for a complete firing cycle.
              Me thinks, hoping i'm right.
              Carlos.
              • caterpillar
                • 2480
                60 degrees
                • Flat on my back
                  • Jan 2007
                  • 2449
                  no...
                  Engine cycle starts at 0 degrees, so the the firing on a 4 stroke would be seperated as:-
                  0, 144, 288, 432 and 576 degress of two complete cycles.
                  Carlos.
                  • gnutz2
                    • Aug 2006
                    • 928
                    Originally posted by caterpillar
                    60 degrees
                    What is 60 degrees.
                    Flat on my back is correct with the 144 deg, i turned the engine over by hand to double check everything.
                    But because the second revolution of the engine is different to the first it means i have to run a camshaft sensor (awkward I5 engines, but sounding good)
                    You can repeat the ignition cycle every 360 deg on a 4 cyl engine, as long as you fire on the exhaust stroke too (wasted spark). Eliminating the need for a cam sensor( easy but not quite as sexy sounding as an I5 engine)
                    The ONLY S2 Golf!
                    10.42@138mph
                    • Flat on my back
                      • Jan 2007
                      • 2449
                      It shoudn't be too dificult to identify the 4 parts of the 4-stroke cycle eg. inlet, compression, combustion and exhaust for the 5 pot engine over the 720 degree rotation, for each pot.
                      You know the firing cycle so work from this, being electrical i'll probably draw some crayon pictures for myself.
                      Carlos.
                      • Audi_CQ
                        • 940
                        • Country: Norway
                        Originally posted by gnutz2
                        What is 60 degrees.
                        Waste spark works just as good on I5 too. No need for a camshaft sensor
                        • gnutz2
                          • Aug 2006
                          • 928
                          Please tell me more, I`ve been thinking about it and cannot see how it is possible as no two cylinders are at TDC at any one time.
                          The ONLY S2 Golf!
                          10.42@138mph
