Still stalling
  • rj scotty
    • May 2006
    • 2195
    Still stalling
    Evening All
    There have been developments with my cutting out issue.
    I have fitted a new G28 speed sensor today and also a rs2 maf.
    Now the violent loss of all power for a split second at mid to high revs has gone
    However I still have the stalling issue at idle.
    Its very intermittent, can happen for no apparent reason or some times when a large electrical load such as A/c or fan switches on.
    I have checked for air leaks and none are apparent and as the car (standard aby apart from 034 coil set and rs2 maf on ABYchip) boosts to 1.4 bar I'm satisfied this is not the issue.
    Which brings me onto the good old ISV.
    I have removed the top pipe and sprayed some carb cleaner into it.
    This appears to have made a marginal difference.
    However would a faulty ISV be the problem when coming back onto the throttle at anything up to 2000 rpm ?
    As the car will still lose all power for a split second, agine super intermittently
    No fault codes apart from "G28 implausible signal which I have ruled out"
    If it needs replacing ill replace it just seams a little strange
    All help greatly appreciated
    cheers
    rich
    PS despite what I have read rs2 MAF onto s2 ABY air box is a straight swap
    BUT I DON'T WANT A NEW CAR!
    1995 S2 Avant, Volcano Black
  • Knight Rider S4
    • 3541
    Have you replaced the fuel filter
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
    • spink
      • 4382
      your best off taking the isv off and soaking it over night and getting all the crap out of it.
      • rj scotty
        • May 2006
        • 2195
        yes has been replaced but you make a good point, fuel pump maybe ?
        fuel pump makes a gurgling sound on start up, has done for a year.
        Has it finally gone ?
        fuel pressure regulator maybe ?
        • rj scotty
          • May 2006
          • 2195
          In what carb/brake cleaner, IPA, petrol ?
          again, all help appreciated
          cheers
          rich
          • Knight Rider S4
            • 3541
            Or relay to worth checking
            93 S2 Avant Parting
            91 URQ RR
            02 A4 tdi Avant
            • rj scotty
              • May 2006
              • 2195
              Would an out put test confirm this ?
              cheers
              rich
              • Knight Rider S4
                • 3541
                To a certain point yes
                93 S2 Avant Parting
                91 URQ RR
                02 A4 tdi Avant
                • spink
                  • 4382
                  Ive always found IPA does a good job.
                  • Acidburn
                    • 13459
                    Just as a possibility when ross did project 400 (his 3b coupe) he found that his turbo was slightly sitting on the chassis and the vibrations kept stalling the car, whats your engine mount like on that side?
                    Probably best to clean the ISV fully to check that is not the problem.
                    • spink
                      • 4382
                      After you have cleaned your ISV(or before even) i believe there is an output test you can do in vagcom to see if its actually moving as it should..
                      • rj scotty
                        • May 2006
                        • 2195
                        I think you need the full version of vag com to do the out put test, however I think this way of doing it should work.
                        As for the engine mount Ill have a look.
                        Ill give you an example though, I had the car running stationary in the garage for 20 minutes no problem then all of a sudden for no apparent reason she stalls, restarts straight way and all vag com says is G28 implausible signal.
                        cheers
                        rich
                        • GT500
                          • Jun 2006
                          • 2181
                          How's the tag on the flywheel? it might have half let go, they are only spot welded on.
                          May have moved just enough to lose the tolerence between sensor and tag.
                          HTH
                          Rob..
                          87 UR 20v ABY
                          97 S6 Avant
                          • rj scotty
                            • May 2006
                            • 2195
                            Ill have a look at that whats the best way to view it ?
                            • GT500
                              • Jun 2006
                              • 2181
                              Take the starter off, turn engine untill it appears
                              Rob..
                              87 UR 20v ABY
                              97 S6 Avant
