Engine designations and parts interchangeablitly?
  • Group_B
    • Nov 2007
    • 5
    From what I've been able to figgure, Audi's NF, NG, 3B and 7A engines are all 2.3 litre. Do they use the same block and are the internals different from N/A and Turbo variants? Also, could you bolt a 7A head to a NF/NG block?
    Reason I ask is that there are more than a few NF/NGs out in the local junk yards, but ideally I'd like to have a 20v DOHC turbo engine, which seem hard to come by.
    Thanks!
    No, 3B is 2.2 Litres as it's an 81mm bore the 7A is a 82.5mm IIRC
    The rods and pistons are different in the NA than the turbo.
    • denniselbows
      • 740
      do the na engines have the oil squirters to cool the underside of the pistons ?
      never set your expectations to high that way you are never disapointed
      • Flat on my back
        • Jan 2007
        • 2449
        Bentley say yes for 7A's, not taken my 2 spare blocks apart yet to confirm
        Carlos.
        • 4WheelDrifter
          • Oct 2004
          • 5773
          • Country: Devon
          My 7A has oil squirters.
          SS
            I'm pretty sure the KV engine (10V 2226cc non turbo K-Jetronic circa 84-89) is the same basic block as 3B and beyond but it doesn't have the oil squirters and wouldn't have come with the higher spec bearings as the turbo engines, but it is the same crank. Dunno the small print though and I'm not up on the NF or NG engines.
            Just a quick check on the old family album...
            KV is 10V 2226
            NG is 10V 2309 so deffo different block to 3B/ABY etc
            Same crank in KV, NG, 7A, 3B, ABY, ADU
            Oil squirters appear to be fitted to all blocks except the early KV.
            2226 Base block part number is 034 103 101
            Suffix for KV is S
            Suffix for 3B is P
            for ABY/ADU is N - same as AAN of course
            That tells me that any change is minor but I dunno what it would be.
            • 4WheelDrifter
              • Oct 2004
              • 5773
              • Country: Devon
              3B and ABY/AAN/ADU blocks are the same. Just the 3B doesn't have the holes drilled for the cambelt tensioner.
              SS
                Doh - yeah - that'll be a thing - well spotted Stu
                I don't really wish to know that a KV engine can be converted into S2/RS2 spec cos I sold one about 5yrs ago in a perfectly working Typ85 Coupe for very bad money simply cos I could no longer store the old girl. Thank lord it wasn't a quattro as I would have given away an 016 transmission as well. Boohoo - the things you do under pressure. Doh
                Paul
                • 4WheelDrifter
                  • Oct 2004
                  • 5773
                  • Country: Devon
                  The 7A block is the same as a 3B apart from the bore as far as I could tell. Maybe I should dig the 7A, 3B and ABY blocks out of the garage and line them up to compare them.
                  SS
                  • terrybullwon
                    • Mar 2006
                    • 8782
                    Does any one have pictures of the two with belts on?
                    I have never thought about this before, i have both blocks also
                    Chef
                    • DJones
                      • Jun 2005
                      • 2020
                      This is an AAN same as ABY and ADU apart from pump size principle is the same.
                      • spink
                        • 4382
                        Re. the cranks,they are different on some 7a vs 3b that ive seen,the shape is same but they are sometimes cross drilled in different places,not sure why.There is a picture on here somewhere,someone has 2 side by side with tie wraps poked through the holes to show the difference.
                        ps ive dug out another 7a bottom end that i want rid of,sooner the better or it will get binned.Free to collector.
                        • 4WheelDrifter
                          • Oct 2004
                          • 5773
                          • Country: Devon
                          That's interesting. I've not tried poking anything through them yet.
                          @ Terrybullwon - Which cambelt/tensioner/water pump/oil pump setup are you thinking of running?
                          SS
                          • terrybullwon
                            • Mar 2006
                            • 8782
                            I dont know
                            I was thinking this the other day after a chat with Jamo....
                            which is the best set up??? (maybe another thread )
                            Chef
                            • Group_B
                              • Nov 2007
                              • 5
                              Thank you guys, this has been extremely helpful!
