Am I missing something here? Why do you have to have a flatbed truck to get an S2 recovered? Why can't it just be towed?
Coolant leak
Towing a 4x4 is always delicate....
Certainly towing it with one set of wheels on the ground and one off is NOT a good scheme and should not be done.
Even with all 4 wheels on the ground its going to be risky and damage my result....
Getting it on a flat bed is the best option.Comment
Cheers Michael!! they do throw out some steam don't they!! ok, so next time I wait until the early morning to break down, good pointer
fingers crossed on my rads..... we'll see.
I was always advised never to tow a Quattro, always insist on a flat bed, or they can pick up the repair bill for towing in with two wheels down! it can do some real bad damage! it's like you *should* always use exactly the same make and depth on all four tyres! if you had say new tyres up front and old at the back, the rear wheels are ineffect a smaller diameter and can wind-up the Quattro system until something gives way!!
MartynComment
No probs towing the quattro's on all fours! Have had to tow mine a couple of times recently
Martyn, you want to phone Audi and order one of those hoses, might be a bit cheaper than that VAGparts lot
LOLsigpic
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nmComment
I had the 4X4 towing problem when mine was being moved between the workshop, the jig man and the body shop.
The bloke who came to move, who is supposed to be a profesional recovery driver, arrived with an towing dolly. My mechanic took one look and told where he could stick it.
Ended up costing me £150 in recovery costs for three journeys (about 8 miles total) because they had to send out the flat bed.
Still better than god knows how much if the quattro system got wound up.
Benthe best intentions are fraught with disappointment - gil grissom
1994 ABY Avant - it's getting thereComment
I was towed at 70 mph on a rope and my car is ok. Maybe i was a bit lucky
Wont be doing that again then!!
Once again this forum comes up with the answers, they might not be right tho!!
LOLsigpic
Audi UR Quattro
In a sea of cow droppings and informed guesses, the S2 owners clear a path to the righteousness of truth, justice and the first thing that they thought of.... then posted it, and looked like a prat :-)
< excerpt taken from 'Tom C's latest best seller 'Me, myself and I, an S2's owners guide to life' > available in paperback, hardback and marker pen on the back of his pubs bog door.
:nana:
