FAO Lee - CR calculations
  • Doug_RS2
    • 3847
    Lee - this is where I got the 4.2cc (off each piston) from to lower CR.
    I think you worked out 3.3cc.
    Maybe Marco or someone else can confirm - to change form 9.3 to 8.7 CR on our cars
    Let B be the compressed volume and A be the uncompressed volume
    A / B = 9.3 (ratio of two volumes) (1)
    and A - B = 445.2cc (volume of stroke) (2)
    Rearranging (1) gives A = 9.3B
    Substituting in (2) gives 9.3B - B = 445.2
    Therefore, B = 445.2 / 8.3 = 53.64cc and so A = 498.84cc.
    Now if we let C be the additional volume required to reduce the compression
    ratio to 8.7,
    then (A + C) / (B + C) = 8.7 (3)
    Rearranging (3) gives A + C = 8.7B + 8.7C
    so A - 8.7B = 7.7C
    and so C = (A - 8.7B) / 7.7
    Therefore, C = (498.84 - 8.7 x 53.64) / 7.7 = 4.18cc.
  • Pisobiker
    • 1175
    Doug, your numbers should be correct. Following is the calculation my way, and result is just the same:
    If OEM initial bore is 81.0mm then bore volume is 444.99 cc
    If we say the metallic head gasket takes OEM engine to 9.0:1 CR then combustion chamber is 444.99 / (CR-1) = 55.62 cc
    If final bore is 81.5mm then bore volume becomes 450.50 cc, while taking 0.2mm off the head and 0.1mm off the cylinder deck will reduce combustion chamber to about 54.30 cc
    Your new numbers are:
    VC=450.50
    VCC=54.30
    so being CR=(VC+VCC)/VCC then
    VCC=VC/(CR-1)
    For CR=8.7 then
    VCC=58.51 which compared to the initial 54.30 cc makes
    + 4.21 cc.
    Marco
    • Doug_RS2
      • 3847
      Thanks Marco - I feel better after getting those numbers confirmed.
      • Lee
        • 1512
        Yep, I agree too. I forgot to consider the chamber volume in the uncompressed charge. I redid the calcs last week as I couldn't figure why my answer was different and came up with what you have.
        Anyway, I blame the Belgian keyboard, Dirty Sanchez and that funny cherry beer!!:wacked: :wacked:
        Inexcusable mistake for such a simple calc really!! I live in shame and wonder why I did my Engineering Degree!!
        Lee
        Designun Limited....
        • Audi Parts Guru
          • 1317
          Lee
          Yeah shame on you Lee
          • Mark Halligan
            • 2001
            LOL, keeping my eyes open for falling satellites now :eek2:
            Mark.
            Mark - Modded
            • Lee
              • 1512
              I insist it was Mihneas dodgy fruity beer, honestly :eek2: :eek2: What other excuse can I find? Oh yeah working 12- 14 hour days for the last few months and then spending hours here is feckin with my brain!! :wacked: It was after a 'spirited' 5 hour drive, several beers and in the early hours of the morning. LOL! Just don't ask me for calcs these days!!
              Lee
              PS Don't worry Mark, we'll give you plenty of notice when not to look up! Just be more worried about all of those cold war nuclear propelled spacecraft that have been floating around for the last few decades.....they WILL be coming down to the earth's surface one day. Ours are so small they burn up completely after about 20 years in low earth orbit. You can now sleep at night! LOL!
