Not sure but would like to check.
I have had a slow coolant leak for some time. I have traced several coolant pipe leaks and sorted them but it continues. No sign of a big gasket leak. i.e. no contamination of coolant, no bubbles, no c**p on oil filler cap, no misfire and its being going on for a couple of years. My logic says would be strange for the head gasket leak not to progress.
But white 'fur' on lambda is a concern as it is said to be a sign of coolant getting into exhaust.
I know I can use an MOT station to check but have heard you can get kits which test for exhaust gases in the coolant system (test filter on coolant cap I think). Just cannot spot one via google.
Thoughts welcome and yes I will triple check for a coolant leak including heater matrix ( I use search
