Differences between 3B & ABY motors?
  • quattro4Life
    • 92
    Sorry for the newbie question, but i was curious as to the differences in the two motors. Is the ABY coil-pack ignition similar to the AAN that we received here in the states? When i finally get the loot to perform an engine swap i plan on using an AAN, so id appreciate knowing the specs of these motors to reference mods and such.
    thanks for the help
    -b
    Im not the percent you think survives,
    I need sanctuary in the pages of this book...
    main difference is the fact ABY/AAN have Dizzy less systems.
    If you check out www.s2central.net most differences are shown.
    There are also difference's witht he water pump, battery location, aircon installations in addition to those listed on s2 central.
