oil pressure, cold, warm, idle, cruise, WOT...
  • lukach
    • Jan 2006
    • 124
    Hi, I did a research and haven't found what pressure have you guys when driving at WOT..I saw that your idles are at 2 bar when warm and round 5 bar when cold.?
    Cruise 5 bar?
    I would like to know what pressure you have when you acclerating with WOT?
    Oil 10w-60 Castrol RS..
    Thanks, for answers..
  • Acidburn
    • 13459
    When warm mine on WOT is around 4-5 bar ish iirc
    Idle 2 bar
    cold idle 5ish
    crusing around 3-4k iirc is about 3-3.5 ish.
    • s2driveruk
      • 12696
      5 bar WOT
      2 bar idle warm
      4-5 bar cold idle
      4-5 bar cruise
      also on same oil
      Sounds fine to me...
      1992 3b S2 Coupe
      • valjo
        • 1110
        • Country: Latvia
        Originally posted by s2driveruk
        5 bar WOT
        2 bar idle warm
        4-5 bar cold idle
        4-5 bar cruise
        also on same oil
        same here. i use also castrol rs 10/60.
        if you have low oil pressure you may have bad oil pressure sensor-i had those problems.
        you could check your oil pressure sensor with dimm meter. if you plan to do that contact me to give you ohm values you should see on healthy sensor.
        Audi Coupe S2 1993
        Audi V8 4.2 1993
        Audi cabrio 1998
