urgent help pls- con-rods
  • timucin
    • Nov 2003
    • 869
    • Country: Turkey
    i found a set ready to deliver to me but we have a problem(or i think there is)
    rod bore is : 1.992 inches
    but on eurospec www, rod bore is 48 mm which is smaller.
    what is the rod bore of adu engine pls?
    Quattro
  • Pisobiker
    • 1175
    Timucin, 48mm is rod journal diameter on crankshaft, then you have the bearing between this and conrod's big end, so 1.992 sounds right to me.
    Anyway to be 100% sure try finding out through a machine shop. They must have all the specs for any car. If they cannot find RS2 (ADU engine) consider 3B, ABY, AAN and many other AUdi engines have same big end diameter (even TDI ones....)
    Marco
    • timucin
      • Nov 2003
      • 869
      • Country: Turkey
      ok thnx for help
      Quattro
