stock cams
  • dainys
    • Jul 2007
    • 9
    • Country: Lithuania
    stock cams
    hello,
    how many HP it is possible to have using stock cams (k26/27, RS2 EM, big IC, 76mm exhaust, injektors).
    The cams won't be the limitation in that setup. Your turbo will define the max HP dependant on the size of the hotside ( exhaust ) of the turbo.
    • Faheemo
      • Feb 2005
      • 544
      • Country: South Africa
      Stock Cams wont help the engine breed in the higer RPM's.
      try a 7a exhaust cam, more lift, more hp in high rpms.
      S2 Coupe fully built.
      10.9 1/4mile 0-100 in 3.5secs
      Precision 6262 turbo
      The Green Monster
      • S4turbo
        • Nov 2005
        • 81
        • Country: Norway
        I know of engines with more than 500 hp, with original cams and unported top. With a gt3040 turbo. Not optimal setup though, rather late spool up.
        J
          Yeh but you lose low end torque, You can do it but it wont hurt the total BHP output if you stick to original cams.
          • Audi_CQ
            • 940
            • Country: Norway
            Why would you lose low end torque? 7A ex. cam has same timing as org. ex cam.
            7A intake is another matter since it got more duration.
            • 20Vcqdriver
              • 829
              timing
              7A exhaust is not the same as 3b. 7A closes some 6degrees later and has a few more mm of lift. Not sure why it should affect low end torque, but you will have to have a re-chip to get the additional fuelling it will require at higher rpm.
              1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
              • Audi_CQ
                • 940
                • Country: Norway
                No. It's got the same timing.
                Yes it has 2mm more lift, but that doesn't create overlap.
                Do a quick search on the forum: "7A cam timing"
                Why a fuel remap The maf sensor should do just fine.......
                • Flat on my back
                  • Jan 2007
                  • 2449
                  Ex 7A vs 3B
                  Is the data in the last post correct? Or we need an edit?
                  Carlos.
                  • 20Vcqdriver
                    • 829
                    Data
                    Carl is correct the 3B ex closes at 9deg before TDC whereas the 7A closes later at 3 deg before TDC and has more lift hence why the standard map will be wrong and the engine run lean at higher rpm, not something the MAF can automatically compensate for.
                    • Audi_CQ
                      • 940
                      • Country: Norway
                      Originally posted by Flat on my back
                      http://www.s2forum.com/forum/showthread.php?t=22712
                      Need an edit i think:
                      DropCatch.com helps you secure expiring domain names.
                      From factory manuals according to writer. In 20_cams_2.xls look at sheet "cams" and part nr is included.
                      • Audi_CQ
                        • 940
                        • Country: Norway
                        Why should it run lean?
                        Think about how the MAF works: It meassures air flow and then fuel is added according to Mass Air Flow. A MAF is the perfect way to compensate for changes in airflow
                        Even if the 7A ex cam was some degrees different, intake airflow wouldn't change much. Most of the gain is in reduced pumping loss
                        • 20Vcqdriver
                          • 829
                          timing
                          Another source that agrees the timing is different (http://www.humanspeakers.com/audi/engines.htm)
                          Due to the change in overlap the maf will get slightly different signals hence leaning, not a problem during cruising as Lambda keeps mixture at AFR 14.7. If the only difference was lift then the MAF would indeed compensate as you stated.
                          • Audi_CQ
                            • 940
                            • Country: Norway
                            As usual: if you want to be sure, don't trust anything you read and do it yourself
                            I've measured open: 42 before BDC, close 2 before TDC(picture is not from 7A cam timing, but results are ) so you're right about timing
                            About MAF: How would overlap make a change to a sensor sitting in front of the turbo? Sure you're not thinking about a MAP-sensor?
