Hi Group,
I'm a new member but been an S2 owner for the past 3 years. Love the car but had problems with it since I had a 303BHP upgrade done to it.
The latest problem is that when I accelerate hard at approx. 3-3500RPM the fuel seems to the cutting out and the car is juddering and pulling back. Most noticeable under heavy load (5th gear uphill) but occurs in all gears.
Its fine till I push more than about 40# down on the accelerator then just pulls back when I push it any more.
Has anyone experienced this? I've got the car in a garage at the moment and they are saying its the coil packs. Now I've spoken to some other guys who say its very unlikely to be this, and check the fuel filter and the plate cover on the coil packs about earthing.
Now in the past I've bought new speed sensor, lambda sensor, solonoid valve amongts other things which hasn't done the job.
Coil packs will cost me many pounds, so I really would appreciate if anyone has had the same problem how it was fixed, as I am clueless here and having already spent thousands on so-called solutions really could do with some advice from someone who as been there.
Hope to hear from you folks soon as the car is in there as we speak and I don't really want to commit to paying for it if its going to be fruitless.
Cheers,
Paul
Cheers,
Paul
