What is the upper hp limit on stock rods?
    Okay, I read this thread:
    However, it is not clear to me what the upper crank or wheel horsepower limit is on stock AAN, ABY or ADU rods. I've been under the impression that anything more than 400 crank hp is starting into the range where you might want/need to replace the OE rods with something stronger. And certainly, by 450 whp, upgraded rods are a necessity.
    Am I wrong on this?
    I was trying to find the photo of the "banana" shaped OE rods to find out what had happened but I couldn't even find the photo.
  • terrybullwon
    • Mar 2006
    • 8782
    Well Its not so much power that bends rods, its torque.
    I think 500Nm is the limit on stock rods.
    Cheers James
    Chef
    • terrybullwon
      • Mar 2006
      • 8782
      banana??
      Chef
      • topsparky
        • Oct 2005
        • 2014
        Cheers James
        i thought it was 650nm james
        then you have to go stronger
        i might be wrong though
        1. SHORT SHIFT KIT
        2. PORSCHE CAYENNE CALIPERS
        3. H & R SPRINGS
        4. BILSTEIN SHOXS
        5. NEW BUSHES AND HP2 STRUTS
        8. fmic fitted
        • terrybullwon
          • Mar 2006
          • 8782
          I think 550Nm maybe dancing with the devil
          Chef
          • topsparky
            • Oct 2005
            • 2014
            ummmm i will bow down to your wisdom
            james
            1. SHORT SHIFT KIT
            3. H & R SPRINGS
            4. BILSTEIN SHOXS
            8. fmic fitted
            • terrybullwon
              • Mar 2006
              • 8782
              I am sure there will be people that will say more, Its down to the owner i guess at the end of the day.
              Also for 400bhp i would look into RS2 bottom end bearings and defently for 450whp
              Chef
                banana?
                What are those rods and pistons from? An I5 20vt (one's missing) or a 1.8 L 20vt I4?
                I need to know because I want to use the photo to help settle an argument, er "discussion".
                TIA
                  S2 rods from a 3B engine bent by an RS2 turbo
                  • topsparky
                    • Oct 2005
                    • 2014
                    i was closer james
                    1. SHORT SHIFT KIT
                    3. H & R SPRINGS
                    4. BILSTEIN SHOXS
                    8. fmic fitted
                      550nm should be your limit anything above and your playing roulette.
                      • terrybullwon
                        • Mar 2006
                        • 8782
                        i was closer james
                        500Nm was just being captin safe
                        Chef
                          http://www.s2forum.com/forum/showthread.php?t=1352
                          It has been suggested to me that "the 3B which had an inferior ignition system which leads to preignition which = BROKEN RODS. Alot of it had to do with people using the incorrect distributor cap (yes there is a difference= narrow points)"
                          Is this the real problem with the 3B that doesn't occur with an ABY or ADU (or AAN)?
                          (I am not being argumentative, just curious).
                          • topsparky
                            • Oct 2005
                            • 2014
                            captain safe or captain SLOW
                            1. SHORT SHIFT KIT
                            3. H & R SPRINGS
                            4. BILSTEIN SHOXS
                            8. fmic fitted
                              What a load of bullsh*t IMO, yes the ignition system is inferior but if you produce to much torque / bhp than the rods can handle they will bend pure and simple.
