ECU Fault code? Internal Control Module Memory Error
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    got the same code,did you find a solution?
    im getting the same signs.Turn the engine off,code appears.Turn on and erase the code doesnt reappear.Earth cables on manifold are checked.I need to check other earth grounds as well
      My money says its a checksum error on one of the ECU chips. Sometimes the tuner gurus forget to do that. I can do it if required.
      PAul
      • A80Avant
        • Sep 2005
        • 10873
        • Country: Greece
        thanks Paul!
        maybe this is something to be done when i come to England....now looking on another issue...
