Rods
  • Pirvu Eugen
    • Apr 2007
    • 1978
    • Country: Romania
    Rods
    Hello!
    I saw that alot of you are prefering the Corrilo or Pauter rods and not Scat wich are more cheap. Question is, Wich are the main advantages and disatvantages between these rods.
    Scat can create problems for an engine with ~ 500 NM ? Or the other 2 are for much more then Scat?
    Thank You!
    Eugen
  • Acidburn
    • 13459
    I've not heard anything bad about scat so far? I currently have a set ready for in mine.
    • Pirvu Eugen
      • Apr 2007
      • 1978
      • Country: Romania
      Thank you for reply.
      I hope is no problem with them also because i have 1 set for my 400 hp project.
      Is confusing because is a big price diference between these.
      Probably the others are more torque resistant. Dont know!
      Hope to be ok!
      All the best!
      Eugen
      • caterpillar
        • 2480
        scat are for the aircooled ones,and the OETTINGER for the watercooled; buth both are in vw/audi/porsche .....i thought it was so...
          Quality is the difference. Pauter and Carillo are the best quality on the market.
          Scat are lower quality rods for those on a tighter budget.
          For 400 bhp they are more than fine, they've been pushed to 600-700 bhp in the US.
          • Pirvu Eugen
            • Apr 2007
            • 1978
            • Country: Romania
            I dont understand! Whater or aircooled rods?
            • Pirvu Eugen
              • Apr 2007
              • 1978
              • Country: Romania
              Thank You!
              So.. for an 400 hp and how much torque i can get from those are more then enough, no?
              Supper!
              Thank You guys and Happy New Year!
              • Acidburn
                • 13459
                Lol well as long as they do what I need them to no probs
                Its not as if my car spends all its time at WOT.
                Tbh in the last week its lucky to have done 10miles.
                • lukach
                  • Jan 2006
                  • 124
                  I saw many 4cyl 1.8t engines running more than 700HP on them..Do you have link where they are talking about bad quality?
                  • DJ-ROY
                    • Dec 2004
                    • 710
                    i think i play it on the safe side with one of those .
                    is it hp or nm that bends rods?
                    RS for ‘Rennsport’ - ‘Motorsport’ in German
                    • A80Avant
                      • 10873
                      • Country: Greece
                      NM in lower rev range is what causes rods to bend
                      • Pirvu Eugen
                        • Apr 2007
                        • 1978
                        • Country: Romania
                        i hope that for ~500+ NM at low rews they will be good.
                        • A80Avant
                          • 10873
                          • Country: Greece
                          im now at 520Nm@3760rpm and have no issues with them.But i am going to transfer the curve a little later to avoid surge.In any case it is difficult to get too much Nm in short revs cause turbo gets bigger and lag as well.Of course if you are building a stroker,thats another thing...
                          • Pirvu Eugen
                            • Apr 2007
                            • 1978
                            • Country: Romania
                            noo! I am trying to achieve an reliable 400 hp with how much down torque i can... Off course depend on the remap... Hope for this the Scat will be enough to not create problems... (i will have aan ecu with 1.8 turbo coils and modified 3B loom for that) About the ignition...I understand that this will be good for the internals..
                            • A80Avant
                              • 10873
                              • Country: Greece
                              well,
                              if you use a garrett turbo,it can boost really low and maybe give you a decent 400hp,but that also brings surging(better thing of some head porting)
                              if you use a thrust bearing turbo(KKK)etc,then you avoid the surge,but high boost will come later.
