I was wondering if these temperatures are ok or what are you seeing those who have an EGT probe.
With mine fitted on the turbo hotside yesterday on a small trip i had the following indications.
6th gear at 130-140Kms(85ml)
1)on level plane and cruise control on(meaning part throttle as less possible to achieve better fuel consumption),being on the middle of the vaccum area of the boost gauge----->700-750C
2)same conditions only this time slight uphill nothing serious,boost gauge showing 0bar of boost now------>800-850C
Overall on the highway the temps where from 700-820C while on cruise control which i wondered if they are ok as Erdal had noticed that the best cruising temp for me would be around 700-750C so not to be lean.
any thoughts?
cheers
vasilis
any thoughts?
cheers
vasilis
