7a head troubles -Help
  • AndersS2
    • 1364
    • Home: Norway
    My 7a head does not have the extra room in the head for the hallsensor.
    Any tips on how to get this machined 100% like the 20vT heads?
    -Bacuse it have to be 100% in the right position, orelse the timing can be bad, right?
    -I do plan to run the oem Motronic
    All help is appreciated greatly as this delays my lovley new engine
    cheers,
    Anders - S2 Avant Clubsport - 8pots or die!
    You have two options -
    1 - Talk to 'spink' on here - he is in the UK unfort for you but has knowhow and experience to add the hall sensor bracket.
    2 - Run with an AAN dissy that 'just' has the hall sensor installed - they were like this from factory at first - lets you run 7A or AAN inlet camshaft and keep direct ignition.
    Paul
    • AndersS2
      • 1364
      • Home: Norway
      So you only need the dizzy which is on the back left side of the head, and put the hallsensor into it, if I have understood you right.
      Is there any pro's or con's running it this way rather than the 'factory' way?
      Cheers paul!
      • urquattro-island
        • Mar 2006
        • 1915
        • Home: Norway Current: Iceland
        hello
        someone got a pic of the aan dizzy?? partnr maybe?? isnt this an upgrade been done to the 3bs??
        japanischer industriabfall nein danke!!
        www.rackeltrim.se Icelandic Division
        • yodasfro
          • Apr 2006
          • 129
          034 does the machining for the AAN CPS bracket. I'm sure you could find a machine shop to do it for you.
          Austin
          1992 urs4 1991 200 20v avant 1990 90q 20v
          • spink
            • 4382
            Anders, any half decent machine shop can do it for you.Just take both the 7a and your old ABY head in.I would have done it for you when i sent you the head but the bridgeport wasnt setup at the time.
            • aronmatic2
              • 2129
              • Country: Hungary
              Cheers paul!
              i using the hal sender in dizzy. no problem. working perfect.
              Real carbon parts for S2 and RS2. Check Carbondesign on facebook
              • Mark Halligan
                • 2001
                I got around the problem by using a slightly altered mounting boss off of an early ABY head (the later heads had this cast into them).
                If you have a spare ABY, ADU, AAN head handy for reference it shouldn't be too hard to make something up.
                The one below is on a converted 7A head and its running perfectly.
                Mark - Modded
                • AndersS2
                  • 1364
                  • Home: Norway
                  Spink, thanks for the PM.
                  Looks like its either the dizzy way or the Mark-H-head-mod then, as my tuner really did not want to machine without a jigg.
                  Thanks for all the fast and good anwsers
                  • spink
                    • 4382
                    Mark, are those boss's available to buy still?
                    • Mark Halligan
                      • 2001
                      James
                      Don't know, I took it off of my old ABY head.
                      I did notice that it didn't have a part number on it though.
                      Mark - Modded
