Snapped Cam Cap Stud
  • s2_bo
    • Oct 2005
    • 6067
    I was just rebuilding the head and everything was going so well. But then when i was torquing up the Cam Cap Studs one snapped. I was only doing them to 15nm so god knows why it snapped but it did.
    Maybe it got damaged when the machine shop had it or maybe i manged to damage it some how. Anyway, point is i need to extract that stud and replace it with a new one:
    030 103 397 A
    Its snapped just at the base of the thread.
    Would it be a good idea to do all 24 of them? Im going to get new nuts too as im not taking any chances.
    When extracting these should it be done like any other snapped stud or is there a easier / special technique to this????
    As always, any help would be much appreciated.
    Thanks.
    Bo
    91 S2 coupé - RIP
    98 S8 - Luxury barge
  • Flat on my back
    • Jan 2007
    • 2449
    Wot...
    Didn't put the cap on wrong way round, please, please say no...
    Spark erosion...nearly needed this on an ex stud.
    Carlos.
    • s2_bo
      • Oct 2005
      • 6067
      No, all caps were on the right way round. I just checked the torque wrench. Its not working properly at all. I think i must have been putting more like 30+nm on to them studs
      That was a very careless mistake of me to use a old click type wrench on something as important as this..
      Therefore they will all need replacing now as the threads are most likely to stressed
      91 S2 coupé - RIP
      • Rusty
        • 18953
        Bad luck Bo.
        I managed to re-do an exhaust stud by drlling it out with a new drill bit (i.e. sharp) and then re-tapped it. It's not a nice job so if you have the time to take it to a machine shop then do. If one snapped unexpectedly at 15Nm then sounds rather dodgy, that just shouldn't happen on a cam cap stud... get the others checked by a machine shop, if they snap then they can sort them out for you at the same time rather than you being high and dry in a barn in De'm.
        You can do it yourself but it's a nerve wracking experience and not for the feint hearted! I wouldn't recommend it as you'll never get it true without a pillar drill and a normal pointed drill will wander if your centre pumch isn't good enough.
        Basically, unless you have nerves of steel then it's time to get it to a machine shop.
        • Rusty
          • 18953
          Sounds like machine shop time son. Easy mistake to make, you have my symapthy.
          • Knight Rider S4
            • 3541
            Should get away with small drill bit for pilot hole then use easy out to extract ?
            93 S2 Avant Parting
            91 URQ RR
            02 A4 tdi Avant
            • s2_bo
              • Oct 2005
              • 6067
              Cheers Andy.
              Yeah. i think your right.. What a PITA though!!! Especially as i have to take all the valve gear out again now too as they will get loads of shards of metal in the head.
              There must be another way......
              91 S2 coupé - RIP
              • Knight Rider S4
                • 3541
                http://cgi.ebay.co.uk/5pc-SCREW-EXTR...QQcmdZViewItem
                93 S2 Avant Parting
                91 URQ RR
                02 A4 tdi Avant
                • s2_bo
                  • Oct 2005
                  • 6067
                  Thanks guys,
                  I think ill use one of these though:
                  Then i dont need to worry about mess from a drill, as the stud isnt broken of at base it should hopefully work.
                  Am also going to replace all 24 studs in case any of the others got over stressed
                  91 S2 coupé - RIP
                  • spink
                    • 4382
                    How many mm's do you have left? those stud extractors dont grip from the base,should think you would need 10mm left on that stud for it to grip.
                    ps Those 'easy out' things on ebay can be more trouble than they are worth in my experiance.
                    • s2_bo
                      • Oct 2005
                      • 6067
                      Thanks Spink, i have 17mm left on the broken stud. So hopefully it will work.
                      91 S2 coupé - RIP
                      • spink
                        • 4382
                        phew,thats good then
                        • topsparky
                          • Oct 2005
                          • 2014
                          bo can you get a drill chuck onto the stud if so then
                          just use that and stick it in reverse
                          1. SHORT SHIFT KIT
                          2. PORSCHE CAYENNE CALIPERS
                          3. H & R SPRINGS
                          4. BILSTEIN SHOXS
                          5. NEW BUSHES AND HP2 STRUTS
                          6. UPRATED HIGH OUTPUT COIL PACK
                          7. ,3" turbo back s/s/ exhaust
                          8. fmic fitted
                          • s2_bo
                            • Oct 2005
                            • 6067
                            OMG, i love this forum sometimes!!!
                            Dean your a legend! That came out with out any fuss at all!!!!!! I owe you now
                            91 S2 coupé - RIP
                            • Fat Audi 80
                              • 10547
                              God I was WAAAY too late
                              WELL DONE Bow.
                              Originally posted by Knight Rider S4
                              That's the kiddy! I have used similar on the rustedstucktightasaknatscock countersunk brake disk screw before
                              Good luck Bow, I doubt the remainder of the screw will be very tight now, it *should* wind out nicely. (Famous last words)
                              Cheers,
                              Steve.
                              The Perfectionist
