Car won't start?????
  • Azman
    • Sep 2005
    • 3205
    Hey guys....
    Just been out to get myself over to rugby and the car won't start... Turns over just doesn't fire up....
    Thoughts
    It all was fine yesterday....
    It's too dark for me to go at it now and the car is parked right up against a skip on the drive so it is hard to work on it even more.....
    WHat I do know is I need to empty the catch tank....
    Other than that I am a bit perplexed as to why it just won't fire up. It tried to then just turned over..???? There is half a tank in the car so fuel should be no problem......
    Pointers and what to look for tomorow other than spark..
    Aaron
    Dark Grey Avant
    RS2 FARB
    Alloy Subframe Bushes
  • ericd
    • Nov 2003
    • 1240
    you know what to do , get the codes, remove the fuses for a while an retry, been going through similar with hall sender, usually will start though even when it's logged errors, 515 g40.
    • Acidburn
      • 13459
      Check you can hear the fuel pump relay and there is fuel getting to the front.
      Is the dizzy gear metal?
      Seems to be quite a few cars lately that have starting problems.
      • Pirvu Eugen
        • Apr 2007
        • 1978
        • Country: Romania
        iff no codes... then remove the spark plugs and clean them.
        I had this once after a short trip at low temps.
        Dont know wy, just hapend.
        hope this helps!
        Eugen
        • Azman
          • Sep 2005
          • 3205
          Yup metal gear on the dizzy, Fuel pump relay is clicking on. Will have to pop a fuel line tomorow to make sure it is getting to the front but it should be.....well it did yesterday..
          Dark Grey Avant
          RS2 FARB
          • Azman
            • Sep 2005
            • 3205
            Right been out, pulled all fuses and checked them, The fuel pump relay is clicking on. Have spark to.....
            Tries to fire but just doesn't..... Thoughts please guys?
            Oh yes, checked as many connections as I can get my hands to and have given all a spray with WD40 just in case there was some moisture in there. Battery is getting low now so need to find the good old battery charger before I try to start it again.....
            Confusing this... Any other idea's??
            Dark Grey Avant
            RS2 FARB
            • Azman
              • Sep 2005
              • 3205
              Oh yes can't pull codes at the mo as the ecu has no power to the vagcom plugs.... Next on the list top sort...
              Dark Grey Avant
              RS2 FARB
                my 20v did soemthing similar a couple times back in the summer... had spark, fuel everything seemed fine but wouldn't start. An hour just fired up and has been fine since
                • Azman
                  • Sep 2005
                  • 3205
                  waiting for my mate to turn up with the jump starter and give it a good wirl then to see if it will catch, drained the battery a bit now
                  Dark Grey Avant
                  RS2 FARB
                  • jade
                    • Jan 2005
                    • 1811
                    Use contact cleaner not WD 40
                    RS 2 580HP
                    • Azman
                      • Sep 2005
                      • 3205
                      sorted it!!!!!! My mate came round with a truck starter which he uses on his scooby. Just needed a big power increase, think the alternator must be on the way out, Noticed that running it is only hitting 12 - 13 volts so needs a bit of looking at there me thinks. You just never think it is the battery when it turns but won't fire... Especially when you prove that you are getting spark. Did run very rough (as in not on all cyl) for about 3 mins then it just sorted itself out. Running fine now but very backfirey on gearchange...... Hmmmmm
                      Time to sort out vagcom methinks so a trip to see the wizard is def in order.....
                      Dark Grey Avant
                      RS2 FARB
                      • Pirvu Eugen
                        • Apr 2007
                        • 1978
                        • Country: Romania
                        Spark plugs are dirty. Remove them and clean with an wire brush. At mine that was the problem.
                        • DJones
                          • Jun 2005
                          • 2020
                          Mine also played up in a similar fashion, didn't like starting, sometimes would crank for ages and nothing.... sometimes would crank and kick back on its self.
                          Ok once started. Turned out to be the starter motor. Naturally it was the last thing i tried.... immediately spot on once changed and still is..
                          • Azman
                            • Sep 2005
                            • 3205
                            Will drop the plugs and give them a clean, won't be helping with the fact that it is running a bit rich atm
                            Dark Grey Avant
                            RS2 FARB
                            • Pirvu Eugen
                              • Apr 2007
                              • 1978
                              • Country: Romania
                              iff is runing rich then you can have what is called spark plug fouling. I hope i said corect!
                              Hope you sort that out!
                              All the best!
                              Eugen
